Cyberdog
Message 1 of 3
Ultra Fast Fibre 2 Plus
Hi,
I have ordered Ultra fast fibre 2 plus, and have received my new Hub 2 ( the black one). However a few months ago i bought two Whole home Wi-fi disks ( the white ones).
Will these discs work with the new black hub 2
Many Thanks
Dave
2 REPLIES 2
pippincp
Sage
Message 2 of 3
Re: Ultra Fast Fibre 2 Plus
They should work with it.
Cyberdog
Message 3 of 3
Thanks for the quick reply. I will give them a try when it has been installed.
