AlwaysOnline
Message 1 of 3
Ultrafast alternative modem/router
Hi
I recently upgraded to ultrafast 1 this morning, which has succesfully been intalled, currenly at 9ms pin, 115.92 down, 11.81 up.
Before that i was on bt infinity 2 80/20 using the open reach modem and the neatgear R7000.
I tried to connect the old openreach modem to the R7000, but it isnt picking it up, do i have to do some fidling in the settings? or is it that the openreach modem is not compatible with g.fast?
Should i buy an alternative g.fast compatible modem or router? or is there a work around?
Can i ask BT for a g.fast modem?
2 REPLIES 2
AndyCoffin
Message 2 of 3
Re: Ultrafast alternative modem/router
I know this was posted a while back but no the white openreach modems are not compatible with g.fast, only the black one is. i dont know if you can get one off bt or not and ive only ever seen 2 on a certain auction website.
There is only 1 3erd party router that i know of which is the ASUS Dsl-ac88u and the only other stand alone modem ive seen in the wild apart from the openreach one is the zyxel XMG5101-S10A but i have no idea if either of them are approved for openreach's version of g.fast.
Distinguished Guru
Distinguished Guru
Message 3 of 3
The Openreach VDSL modem is not compatable as it does not have the G.Fast chipset so no work around.
Router vendors are already producing compatable routers , e.g. the ASUS DSL-AC88U is compatable. It all depends on your preference and budget.
