Message 1 of 7
Unable to Connect to BT Infinity using TP-Link Archer VR400
I have finally had enough of my HH5 reliability (or lack thereof), and after some research invested in a new TP Link Archer VR400 modem router. Many reviews highlighted how easy it was to set up.
Except of course, its not. Despite entering the same username and password (bthomehub@btbroadband.com pw blank) as is on my HomeHub, the TP-Link refuses to connect to the broadband.
Its not the connection, as when I put the cable back into the HomeHub, it connects. Unplug and pop it into the back of the Tp-Link, and it fails to connect.
Any suggestions before I return the router as faulty?
6 REPLIES 6
Message 2 of 7
Re: Unable to Connect to BT Infinity using TP-Link Archer VR400
Did you select BT VDSL from the drop down list at the start of the wizard?
Message 3 of 7
Yes - I made that mistake first off, then corrected it!
Message 4 of 7
Did you factory reset the TP Link before making the revised setting? If not, it's worth trying and starting again.
Message 5 of 7
Will try that later and report back.
Message 6 of 7
In the isp list it should have BT_VDSL. At least it did with mine. I don't even remember having to put in a password.
Message 7 of 7
Did that last night and it worked! Thanks!
