MrGL
Message 1 of 2
Unable to connect to ubi.com/uk and uplay.ubi.com and Assassin Creed 4 website for over 1 week!
About 1 week ago I was suddenly unable to connect to the uplay website. When I tried to use the Uplay launcher it basically just sits there waits, attempts to find update (and timeout) then attempts to login (and timeout). When I try to visit www.ubi.com in the both web browsers (IE and FireFox) it redirects to http://ubi.com/UK/ and does NOTHING !
After some googling around I found many, many more people are having (or have had) the same issue in the past.
I have NOT changed any firework/AV settings. I have NOT installed any software.
If you go to http://www.downforeveryoneorjustme.com/ and enter ubi.com or uplay.ubi.com I get a message saying the website is up and running.
IS BT BLOCKING THIS DOMAIN?
and
IS THERE ANY WORKAROUND FOR THIS?
1 REPLY 1
Message 2 of 2
Re: Unable to connect to ubi.com/uk and uplay.ubi.com and Assassin Creed 4 website for over 1 week!
