rinsley
Message 1 of 2
Unable to use SIP VOice Calls
Hi there,
I am unable to use Company supplied VOIP .  I  receivie a message saying Make sure SIP is allowed.I have reviewed the community and there are a number of related messages and I have attempted the following to fix , but still I am unable to use this.
  • Disable Parent Controls
  • Disable Web Address Help
  • REset Home Hub 5 (TYpe B)  Version:1.0   Software version v0.07.06.01239 - BT Last Updated 14/03/2017
Any help appreciated.
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: Unable to use SIP VOice Calls
Hi. Welcome to the forum. The VOIP is it an app on the phone or a program on a computer?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
