longwave
Newbie
Message 1 of 15
Unable to use shortened links from bit.ly on BT broadband
bit.ly is a link shortening service widely used on Twitter and other platforms. For a number of weeks now I have been unable to access any https://bit.ly/ URLs from my BT fibre connection.
In Chrome I get the following error:
This site can’t provide a secure connection
bit.ly uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
In Firefox I get the following error:
Secure Connection Failed
An error occurred during a connection to bit.ly. Cannot communicate securely with peer: no common encryption algorithm(s). Error code: SSL_ERROR_NO_CYPHER_OVERLAP
This can be reproduced on all devices on my BT connection, wired or wireless. As soon as I use another provider, the problem goes away and I can successfully access bit.ly links.
If I perform a DNS lookup then bit.ly resolves to 81.130.111.239 on my BT connection, which is a BT owned IP. From outside of BT, for example via CloudFlare or Google DNS, it resolves to 67.199.248.10 and 67.199.248.11.
I have also seen a handful of similar reports on Twitter where people report the same error messages when trying to access bit.ly links. I wonder if this is some kind of network level blocking or filtering that is somehow misconfigured?
14 REPLIES 14
Shevek
Newbie
Message 2 of 15
Re: Unable to use shortened links from bit.ly on BT broadband
Do you have BT Parental Controls enabled?
That was causing the issue for me.
I logged into My BT, and added http://bit.ly the My Allowed websites section and I can now access bit.ly links again
Moderator
Moderator
Message 3 of 15
Hi @Shevek,
Thank you for posting that's a good suggestion.
@longwave If you have Parental Control can you Try adding that link to your allowed list?
PaddyB
I_Persius
Message 4 of 15
Hi, Thanks for that. The parental controls safe site add worked for me too.
But, this surely is a problem with the recent router upgrade. The BT engineer hadn't heard of it at all and didn't seem to know anything about it until I pointed him to this thread here. ho hum. Not good
Shevek
Newbie
Message 5 of 15
Router upgrade?
Are you referring to your Home Hub or a BT side router?
If its the Home Hub, I can confirm that it's nothing to do with that - I have never used one, I have TP-Link VDSL router and still had the issue.
I_Persius
Message 6 of 15
home hub, it's the gen 6 model we have fibre to the home.
Message 7 of 15
Its not a hub problem, its a parental controls network problem.
meatyguffs
Newbie
Message 8 of 15
I didn't have Parental Controls on, but still hit this problem.
I was advised to switch off "Web Protect" (In account settings) until they have fixed the problem.
I_Persius
Message 9 of 15
Except that parental controls are turned off
I_Persius
Message 10 of 15
Interestingly you can get rid of the problem by turning parental controls on and then setting up the Bitly website as a permanent exemption. The problem with that is that I publish books and design covers, that means a lot of photo sites that I use for work won't run as they also carry nude glamour photos. It's a real problem having to constantly turn stuff on and off to work.
