JSB1980
Message 1 of 4
Unblock US via the Home Hub 5?
Does anyone here have BT Infinity and the Home Hub 5 and use Unblock US or any of the other region-unblocking services?
I've read conflicting reports, and have started to wonder if the unblocking only works depending on how old the Home Hub is. I'm clueless at this sort of thing, so if anyone can guide me through this in layman's terms, I'd be very grateful!
Tags (2)
3 REPLIES 3
Wilray
Message 2 of 4
Re: Unblock US via the Home Hub 5?
Hi JSB, I do not use Unblock US though to me it sounds more or less like a regular VPN service which targets customers looking to view US oriented content.
I never tried to run a VPN at the router /modem level when I had the Home Hub 5, however I can't imagine it being a problem. From what I remember there's a VPN tab in the advanced section and from there you input your VPN login details.
Hopefully someon else chimes in.
Jonkarra
Expert
Message 3 of 4
Unfortunately not possible. Its not possible to terminate a VPN directly on a HH5 additionally the DNS servers are not configurable either.
JSB1980
Message 4 of 4
I thought not 😞
Thanks Jonkarra.
