seniorshot
Message 1 of 7
Unidentified device showing in event log on HH6a
I have noticed from the HH6 event log that periodically a device is connected to the Hub via wifi which I can't identfy. The Mac code for this device  is 80:1F:02:94:1E:12. This equates to a Vendor called Edimax. I have no devices from this company. The length of time it is connected varies.
I recently was on holiday for 2 weeks. The Router was left powered on, and  even during this period this device was periodically connecting and then subsequently disconnecting.
I can also report that I live in a very rural area and that no-one is parked in the vicinity using my broadband connection.!
Here is a picture from a section of the log:-
I should add that the MAC code does not show in any of the listed devices on the "My Network" page.
I am hoping that some of you experts will be able to shed some light on this issue. Is it something I should be worried about?
Many thanks in advance for anyone's help in this issue.
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: Unidentified device showing in event log on HH6a
@seniorshot
Its probably just a random passing device with an Edimax wireless card in it.
If you have BT Wifi/FON active on your home hub, then it could be someone using that. The IP address issued would not normally show up.
That is a totally separate network which is isolated from your own private network.
The device was never issued with a private IP address so it did not connect to your own broadband, so nothing to worry about.
seniorshot
Message 3 of 7
Thank you Keith for your swift reply.
The strange thing is I live up a country lane which is a no through road with virtually zero traffic. Connections of this device also happen in the middle of the night!  I have only 2 neighbours both too far away to pick up my Wi-Fi signal.
I also do not have BT Wi-Fi enabled on the Hub.
The mystery deepens !!
licquorice
Message 4 of 7
Do you have a wireless access point as well as the hub? Edimax manufacture WAPs.
seniorshot
Message 5 of 7
No I'm afraid not.
This will probably turn out to be something stupid, but I've gone through all my devices and  drawn a blank for this device.
gg30340
Message 6 of 7
Powerline adaptors?
seniorshot
Message 7 of 7
No don't use them. I do have a TPlink WiFi extender but this shows up in the list of devices and is assigned a IP address.
