nihaldes
Message 1 of 4
Unnecessary extension sockets
We have recently moved into a new property and have got BT TV and Broadband.
There are a number of extension sockets around the house and loads of telelphone wire which we would like to remove. The BT hub is plugged into the master socket, is there a way to remove the extension sockets and wires as we don't need them and they are unsightly.
I believe BT charge around £100 for an engineer to come and look at the problem but I think this is quite costly to just remove some sockets and wires.
3 REPLIES 3
licquorice
Message 2 of 4
Re: Unnecessary extension sockets
Simply undo the 2 screws holding the removable faceplate of the master socket and disconnect the wires. They will just pull out of the idc connectors.
nihaldes
Message 3 of 4
Ok thanks, and for extension wires that are coming through the skirting can I just cut these?
licquorice
Message 4 of 4
As long as you don't cut the incoming line!!
