Robin1967
Message 1 of 2
Up grade to Infinity
I'm upgrading from broadband (hub 3) to infinity (hub 5) tomorrow and I wish to know two things
1 When is says I should remove old equipment does this include the old broadband accelerator
2 Do I remove all old bt hub software off any computers
Thanks in advance
Robin
1 REPLY 1
Message 2 of 2
Re: Up grade to Infinity
See here for how to set up Homehub 5 depending if a self install or an engineer install.
http://bt.custhelp.com/app/answers/detail/a_id/46549/~/bt-home-hub-5
While you do not need to remove the BT software I would recommend that you do. it is not needed for anything on your computer and often causes more problems than it ever solves
