lotie100
Newbie
Message 1 of 4
Updating apps on my Smartphone not working over wireless - error 495
Although I can update apps and install new apps over mobile data, if I do this at home using my wireless connection, i get an error 495 on the Playstore.  Every connected device in the house gets the same error if using the wireless connection.  I have spoken to the Broadband people and there is nothing wrong with my connection - also, my internet works fine, otherwise.  I have made lots of changes as suggested by other forums but, as I can update over mobile data, I am now thinking that this is wireless secific.  Any ideas, please?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Updating apps on my Smartphone not working over wireless - error 495
@lotie100 Welcome to the forum and thanks for posting, do you have parental controls activated on your broadband connection? I've seen posts before were customers have problems with the play store caused by the parental controls restrictions.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
lotie100
Newbie
Message 3 of 4
thank you Neil - that's the issue sorted Smiley Happy
Moderator
Moderator
Message 4 of 4
@lotie100 Brilliant, I'm glad that sorted it for you.
Kudos”
