Message 1 of 6
Upgraded to 900Mbs, but getting nowhere near those sort of speeds.
I have been using 500Mbs Full-Fiber and my speeds were great. Always around 450 to 500 Mbs as promised.
Yet, a few days ago I decided to upgrade to 900Mbs internet, but there is barely any difference. My speeds went from
around 450 to around 500-550. Some 400 less than my estimated speeds.
So what are my options? Could it be because I am using WIFI? (I have wi-fi 6 built into my motherboard, max download of 888 Mbs)
Is it worth trying ethernet? I haven't because my computer is not in the same room as my router.
If all else fails, what are my options? I could apply for the 20 quid rebate, but I would be better off going back to my 500 contract I think.
Any advice?
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: Upgraded to 900Mbs, but getting nowhere near those sort of speeds.
I've been considering getting a long ethernet cable, but if I do, can anyone tell me the best kind? One capable of 900mbs transfer? Would any work or do I need a specific type?
Message 3 of 6
Even really sexy WIFI equipment will struggle to get above 600Mbps without ideal conditions and semi-pro setup.
500Mbps is a good WIFI result.
A cat5e cable will be fine for 1000Mbps over 100Meters, there is of course higher rated cat6 cables but generally for alot of use cat5e is still a perfectly usable cable. I am still using mostly cat5e on a 2500Mbps network, works without issue.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 4 of 6
Hi,
I found a old ethernet cable from when I had virgin, I tried it with latest drivers, and in the hardware section it says the connection is (1000mbs down/1000mbs up) - but strangely enough, all speed tests I try say it is now running even slower than wi-fi, a pretty steady 300mbs or so.
Could this be because of the cable? The ethernet I'm using is built into my mobo, which is, asus tuf gaming b660-plus - and the controller is, Intel(R) Ethernet Controller (3) I225-V
Message 5 of 6
Actually it's now working full speed. I think steam might have been downloading in the background. I get a solid 900mbs + now.
Thanks for your help.
Message 6 of 6
TUF Gaming board and you were using WIFI? Come on man.... 🙂
All the Virgin cables I have lying around from previous installs are CAT6 which is pretty nice, however they arent very flexible.
Glad its working, ethernet is the way!
