tsmith101
Message 1 of 2
Upgrading from Home Hub 4 to Smart Hub 2
Hi All,
I'm looking for some clarification, I currently have a Home Hub 4 which is connected to the OpenReach Modem on the WAN port.
I just received a new Smart Hub2 which does not have this port, looking on the BT setup guide it says you may have the wrong one, so called the helpline and got told I should remove the openreach modem and connect the new hub to a filter.  However everything else I am reading online conflicts with this.
Can people confirm if upgrading means you remove the Openreach modem or if that stays and i have the wrong hub?
Thanks in advance
1 REPLY 1
licquorice
Message 2 of 2
Re: Upgrading from Home Hub 4 to Smart Hub 2
You no longer need the Openreach modem, just connect the phone socket to the DSL socket on the SH2 via the filter if you are currently using one
