CYMRUCHRIS
Message 1 of 9
Upgrading to TP-LINK VR600 from BT Smart Hub 2
Hi all, I'm trying to do the above using quick setup on the TP-LINK VR600 I have selected BT VDSL as provider and username as bthomehub@btbroadband.com and tried the password as blank and bt but no luck.
I saw in a post changing DNS setting in advanced to VDSL2 but that didnt work either, any advice would be appreciated.
8 REPLIES 8
licquorice
Message 2 of 9
Re: Upgrading to TP-LINK VR600 from BT Smart Hub 2
Did you set operation mode to DSL modem router mode?
CYMRUCHRIS
Message 3 of 9
Didn't see that setting just went through quick setup TP-LINK said thatI need to contact BT to get VCI or VPI settings etc? Thanks
CYMRUCHRIS
Message 4 of 9
Sorry just checked that mode is selected
CYMRUCHRIS
Message 5 of 9
Screenshot (61).pngScreenshot (62).pngScreenshot (63).pngScreenshot (64).pngScreenshot (65).pngScreenshot (66).png
licquorice
Message 6 of 9
You appear to have G.Fast, the VR600 is not G.Fast capable.
CYMRUCHRIS
Message 7 of 9
Thanks for your quick response can you recommend a alternative please?
licquorice
Message 8 of 9
The ASUS DSL AC88U is G.Fast compatible as is the TP Link AC2800 GC430-G2v be careful with the TP Link there are 2 versions of the AC2800, this one and another https://service-provider.tp-link.com/g-fast/gc430-g2v/
CYMRUCHRIS
Message 9 of 9
Thanks for your help appreciate it 🙂
