Message 1 of 1
Usb hard drive to hub
Ok I have a BT hub and I have a hard drive that is connected via usb to the hub, Its worked fine for 2 year but today it wont connect, If I remove it and connect direct to laptop via usb (using same cable) I can see all the files and open them, so I then put a usb memory stick in hub and it work's fine, any ideas?
