rizla13
Message 11 of 22
Re: Use Bt business smart hub at home
Ok thanks. I’ll give it a try when i get home and update
Is it better to factory reset the hub?
licquorice
Message 12 of 22
Yes, its always a good idea to start with a clean config.
rizla13
Message 13 of 22
Lastly which Ethernet port do i use from the business hub to the Linksys velop. There are 4. Can i use any or has to be a certain one?
licquorice
Message 14 of 22
Probably won't matter, not sure if only 1 port is activated when in bridge mode. If so, it is likely to be either port1 or port4
Keith_Beddoe
Message 15 of 22
@rizla13
Does the Business Smart Hub have a phone socket for Digital Voice on it like the Residential one?
If it does, then I wonder if BT Digital Voice will work if the hub is in modem only mode, as that would provide a solution to those people who want to use their own router with DV.
And if BT gave the option to enable modem mode on the SH2, that that would keep a lot of people happy.
rizla13
Message 16 of 22
No it doesn’t
just the usual usb 4 ethernet ports
i wish they did have this option. Virgin do it. Don’t see why BT don’t. It would make life easy for soo many people
Keith_Beddoe
Message 17 of 22
@rizla13 wrote:
No it doesn’t
This seems to say something, see the green socket. different https://btbusiness.custhelp.com/app/answers/detail/a_id/55020/~/how-do-i-set-up-my-bt-business-smart...
rizla13
Message 18 of 22
Cool. So i take it the wan port is port 4.
the link you sent is a smart hub 2. I have sh1. It is not labelled wan but i will give port 4 a try first
thank you
Keith_Beddoe
Message 19 of 22
@rizla13
Lets hope you do not have to use DV in the future.
licquorice
Message 20 of 22
thank you
You don't use a WAN port, that would be if you were using the hub as a router with a separate modem. However, port 4 may be the LAN port that is active when in modem mode.
