Message 1 of 6
Using 3rd party router to replace BT smart hub on by infinity
Hi
My BT smart hub been playing up lately. A lot of orange/green light. I'm thinking of replacing the router. I have TP link archer D20 ac750 router but I'm not sure if it is supported. I haven't had much luck trying to set it up. Is TP link D20 supported on infinity?
5 REPLIES 5
Expert
Message 2 of 6
Re: Using 3rd party router to replace BT smart hub on by infinity
No.  That link describes an ADSL modem.  You want one that supports VDSL for using with Infinity.
Have a look at the Archer VR600.
Message 3 of 6
What router would you recommend to use in infinity at a budget if no more than £40
Expert
Message 4 of 6
You could have a look at the TP-Link TD-W9970.  At same place you saw the first one.
Message 5 of 6
There is only one at that price, the 9970 that @Liam_ recommended.
Message 6 of 6
Ordered it and it's coming tomorrow. Hope it ends my nightmare with smart hub. Tired of green/orange light, pretty much no internet today
