- Mark as New
- Bookmark
- Subscribe
- Subscribe to this message's RSS Feed
- Highlight this Message
Using BT Home Hub 5 as wireless extender
I am trying to change my settings on my old Hub5, something I have done before, but this time I thought I would do it properly after reading articles and watching utube videos and began by performing a reset as recommended.
This was completed successfully and turned off my Wi-fi on my MacBookPro and connected the Hub5 via an Ethernet cable to the MacBook. Opened a browser and typed in 192.168.1.254 and a message came up saying I was not connected to the internet, correct. I then opened another browser and had the same message. For some reason I am not able to connect to the Hub5 manager but I am unable to work out why. Can anybody help ?
- Mark as New
- Bookmark
- Subscribe
Re: Using BT Home Hub 5 as wireless extender
Give your MacBook a static IP address of 192.168.1.1
- Mark as New
- Bookmark
- Subscribe
First check that the Mac has obtained a 192.168.1.x IP address from the HH5. If you've previously turned off the HH5's DHCP server (as you should for this setup), then maybe the reset hasn't turned it back on.
Having played around with this recently, be aware that the HH5 will be constantly looking for an Internet connection & flashing it's lights like it's Christmas. I don't believe they can be turned off in the HH5.
- Mark as New
- Bookmark
- Subscribe
- Mark as New
- Bookmark
- Subscribe
- Mark as New
- Bookmark
- Subscribe
From Google:
To find your IP address on a Mac, go to System Preferences > Network and select your connection in the left sidebar. Then click Advanced > TCP/IP and you will see your computer’s IP address next to IPv4 Address and your router’s IP address next to Router.
Being able to see a WiFi SSID has nothing to do with having an IP address. Or do you mean you can see the web interface? Be aware that both Hubs will have the same 192.168.1.254, which is why the first thing you need to do is change the address of the HH5.
Assuming your reply at 13:43 was to @licquorice's suggestion to set a static IP, I'm curious how you did that if you don't know where to find the IP address?
- Mark as New
- Bookmark
- Subscribe
- Mark as New
- Bookmark
- Subscribe
- Mark as New
- Bookmark
- Subscribe
That implies that the DHCP server in the HH5 is disabled or the network cable is faulty. I'd try another reset of the HH5 first. If that still doesn't work then change the Mac DHCP to manual & set IP address 192.168.1.1, subnet 255.255.255.0 & router to 192.168.1.254. If you still can't connect try another network cable.
Once you've changed the IP address of the HH5 away from 192.168.1.254 so it doesn't conflict with the main hub, you'll nee to change the router address in the Mac setting to match.
- Mark as New
- Bookmark
- Subscribe
