BigAde
Message 1 of 6
Using EE smart hub on BT broadband fttc
Hi - I've recently switched from EE fttc broadband to BT fttc broadband.  My switch completed on Monday, but I never had time to switch over to the BT hub.  To my surprise the old EE smart hub is still working two days later.  I know BT now own EE, but is this expected behaviour? And can I just leave it on the EE hub and keep the BT one as spare?
5 REPLIES 5
albertj
Expert
Message 2 of 6
Re: Using EE smart hub on BT broadband fttc
Hi @BigAde
Welcome to the Community!
Are you sure the transfer completed?
EE uses different PPPoE Authentication details.
If you call 151 do you get BT?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
BigAde
Message 3 of 6
Hi AlbertJ
yes and yes!
thanks
lifeonmars
Message 4 of 6
Also You can use a BT Hub with Plusnet another BT Company.
BigAde
Message 5 of 6
Ok. So I guess this is expected behaviour?
lifeonmars
Message 6 of 6
It depends if the firmware allows it,  I know a lot of plusnet customers use a BT Hub  or smart hub  instead of plusnets, Hub One which is  a rebranded HH5. It would be interesting if a BT hub would work with ee though ?
