Message 11 of 13
Re: Using TP-Link W9970 router as Access Point to Home Hub 5
Yes, everything at default. Which LAN port are you using on the 9970, try a different one.
bratman91
Message 12 of 13
Thanks to your very welcome help, I have now solved the connundrum. It turns out that the powerline adapter must be connected by ethernet to the WAN/LAN port of the W9970 and not any of the LAN ports. This is contrary to advice on the internet that the WAN/LAN port must not be used. The only setting needed is to select the wireless router mode (apart from security settings such as SSID password and router login details). Once again, thank you for your help and patience.
Moderator
Moderator
Message 13 of 13
Great to see you got this sorted @bratman91 . Fantastic advice from @licquorice  (kudos to you :smileywink:)
Cheers
Davaid
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
