bradderz_lfc
Message 1 of 2
Using an old Home Hub 3.0 as second router
I have upgraded to the Home Hub 5.0 which has been going well, I also have an old Home Hub 2.0 running as a second router, but i have now accruired a Home Hub 3.0 so I'm looking at swapping it over.
I currently have them connect via an ethernet cable but I had to change some of the setting on the IP address last time I seem to remember but i can't remember exactly what i changed, can anyone help with what I need to change?
1 REPLY 1
brianhes
Message 2 of 2
Re: Using an old Home Hub 3.0 as second router
With the old router turn DHCP server off, and change its IP address so that is doesn't clash with the main router's IP address nor its DHCP range.
