Message 21 of 26
Re: VLAN on Smart Hub 2 Using a Switch
Fair enough
Message 22 of 26
I think I replied to the wrong message too tbf lol. Meant to reply to Jay Morley
Message 23 of 26
Replies are sequential. You either need to quote the post you are replying to or use the @ function to tag the poster.
Message 24 of 26
This is for both you and @licquorice
I have very limited knowledge however I feel my daughter is over complicating things somewhat, looking for a super secure setup. She’s querying the DDNS as a security measure, I’m guessing it isn’t one on its own and is merely to handle the IP aspect?
She’s looking at a VPS whilst using a VPN at server level and wire guard. Whilst I don’t know the specifics it feels like overkill compared to what’s been suggested by Licquorice.
Message 25 of 26
Total overkill. All DDNS does is track a changing IP address.
If she doesn't want to use it, she can just tell her friends her current IP address and they can connect directly.
Message 26 of 26
If you aren't careful, those security steps you take can make you less secure!
I use a DDNS, and it has a couple of devices setup as hosts - if I'm not careful, that could give someone easier access to my network.
The same with using a VPN.  I use a VPN when I'm away, that dials back to a VPN server on my home router, doing that adds some security.  But using a VPN client on your home router, or from within your network, can, if not properly configured, add an additional route into your network - making it less secure!
*You don't normally need to use a VPN with a VPS.
**I do kind of trust BT, any breaches are far more likely to through incompetence than malice!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
