kitchag
Newbie
Message 1 of 3
VOIP Phone not working on Home Hub 5
I can see from previous posts that this has been an issue and although I have tried all the suggestions nothing seems to work. Can anyone help?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: VOIP Phone not working on Home Hub 5
What make and model is the voip phone?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
kitchag
Newbie
Message 3 of 3
I had a spare router at work so have just connected this and VOIP phone now works fine so clearly a problem with BT Home Hub.
Problem not solved but got around!
Thanks anyway.
