cmprior
Message 1 of 3
VPN Tunnel
Hi
I found the following entries in the logs (HomeHub 3)
I am concerned as I do not recognise this. Should I be concerned that the hub has been hacked?
 09:58:19,15 Oct.OpenWiFi tunnel down
  09:58:19,15 Oct.ISAKMP-SA deleted 81.135.225.207[500]-109.144.192.22[500] spi:5a527545f16997a7:3d3269362c272dee
  09:58:18,15 Oct.Now, begin to send delete SA2 message to: 109.144.192.22[500]
  09:53:18,15 Oct.DPD R-U-There-Ack received
  09:53:18,15 Oct.DPD R-U-There sent (0)
  09:48:18,15 Oct.DPD R-U-There-Ack received
  09:48:18,15 Oct.DPD R-U-There sent (0)
  09:43:08,15 Oct.IPsec-SA established: ESP/Tunnel 109.144.192.22[0]->81.135.225.207[0] spi=144689273(0x89fc879)
  09:43:08,15 Oct.OpenWiFi tunnel up
  09:43:08,15 Oct.initiate new phase 2 negotiation: 81.135.225.207[500]<=>109.144.192.22[500]
  09:43:07,15 Oct.ISAKMP-SA established 81.135.225.207[500]-109.144.192.22[500] spi:5a527545f16997a7:3d3269362c272dee
  09:43:06,15 Oct.
initiate new phase 1 negotiation: 81.135.225.207[500]<=>109.144.192.22[500]
2 REPLIES 2
Message 2 of 3
Re: VPN Tunnel
Its the BT Wifi VPN tunnel used to carry connections to users using your BT WiFi/FON hotspot transmitted by your home hub, nothing to worry aboit.
cmprior
Message 3 of 3
Re: VPN Tunnel
Thanks for the information.
I have been having some issues recently and was concerned the HH3 had been hacked. This the first time I have seen these entries in the logs.
