Michael528
Message 1 of 23
VPN connection to work
When trying to connect to work using the CiscoAnyConnect VPN I keep getting the message below from Cisco.  All other connections and devices work OK when connecting to the internet. Any help please? Thank you.
'The service provider in your current location is restricting access to the internet. You need to log on with the service provider before you can establish  a VPN session. You can try this by visiting any website with your browser.'
22 REPLIES 22
Keith_Beddoe
Message 2 of 23
Re: VPN connection to work
Welcome to this user forum.
Are you a business or residential customer?
Michael528
Message 3 of 23
Residential Keith
Keith_Beddoe
Message 4 of 23
Which BT Home hub are you using?
Have you made sure you can connect to the Internet, before starting the VPN?
Are you connecting using wireless or Ethernet?
Michael528
Message 5 of 23
Smart Hub 2 with 1 Wi-Fi Disc. I think it is the very latest
Michael528
Message 6 of 23
I have been swopping from one to the other in an attemot to solve the problem
Keith_Beddoe
Message 7 of 23
If you are using a wireless connection, can you make sure that your computer is not accidentally connecting to BT Wifi/FON and not your normal wireless connection, as that would account for the need to login first?
Have you tried connecting direct to the home hub, using an Ethernet connection, to see if the problem is still there?
Has this only happened since you got the new smart hub 2?
Michael528
Message 8 of 23
I always check my connection before I start working
Keith_Beddoe
Message 9 of 23
Have you seen this Cisco help page https://www.cisco.com/c/en/us/support/docs/security/anyconnect-secure-mobility-client/118086-technot...
Captive Portal Hotspot Detection
You can disable that option.
Michael528
Message 10 of 23
I was told the VPN would drop occasionally when I had Home Hub 5. but the frequency has increased since I got the Smart Hub. A BT engineer once told me the VPN drops because the Hub is so powerful.
I have an Ethernet cable connected directly to the Smart Hub.
