Michael528
Message 11 of 23
Re: VPN connection to work
Thank you very much Keith. Will let you know how i get on when I get home. Been using a work PC and internet to try and solve the problem.
Keith_Beddoe
Message 12 of 23
@Michael528 wrote:
I was told the VPN would drop occasionally when I had Home Hub 5. but the frequency has increased since I got the Smart Hub. A BT engineer once told me the VPN drops because the Hub is so powerful.
You were told a load of rubbish, it should not drop out, as long as you have an Internet connection.
Michael528
Message 13 of 23
Nice one Keith. I think you definitely have the solution. Can't wait to get home and give it a go. Will let you know how i GET ON.
Michael528
Message 14 of 23
Keith the one button that I need is missing. I only have four
Keith_Beddoe
Message 15 of 23
Perhaps you have a different version of the client?
As you can see, it mentions the exact message you are seeing, so it does appear to be a client issue. Perhaps Cisco or one of your work IT people can suggest a solution?
I assume this is the first home hub you have used with BT broadband, although I cannot see it being an issue, otherwise there would be other posts on the forum.
Keith_Beddoe
Message 16 of 23
@Michael528
Just a thought, have you made sure that Smart Setup  is turned off on the home hub, as that causes lots of problems, and may be the cause of the message you are seeing, as the VPN client is being intercepted by smart setup?
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Michael528
Message 17 of 23
Will give that a go now Keith. I have screen shots but I am struggling to post them. Not the best at that kind of thing. Thank you for your continuing help.
Keith_Beddoe
Message 18 of 23
Screenshots are uploaded using the photo icon on the toolbar.
I doubt they will be much use to me, as I am not familiar with that client, and its a very long time since I had to use a VPN, as I am now retired.
Michael528
Message 19 of 23
Keith I have turned Smart Set Up off (it was set to on) My screen shots are too big to send at the moment. Will mess with them now. But you may have cracked it.
Keith_Beddoe
Message 20 of 23
Its often the simplest things that are overlooked.
"Smart?" Setup has to be one of the worse features of the home hubs, it causes loads of problems for many people, and should have been removed a long time ago.
