Anonymous
Not applicable
Message 31 of 41
Re: VPN issues
That's OK. What Hub have you got? the reason I ask is explained here, pay particular attention to message 22.
Martin955
Message 32 of 41
Re: VPN issues
A brand new type 6
Anonymous
Not applicable
Message 33 of 41
Re: VPN issues
Have you reset your hub?
I've just found a few threads on this community on this issue and a common theme (and solution) seems to be turning off Smart Setup. Click the link below for help on how to do so.
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Martin955
Message 34 of 41
Re: VPN issues
I turned smart set up off a couple of weeks ago. It has made no difference.
Anonymous
Not applicable
Message 35 of 41
Re: VPN issues
That's me out of ideas I'm afraid. Did you try factory reset?
Martin955
Message 36 of 41
Re: VPN issues
Yes just done it.
I'm trying to get some work done, so sticking with the Vodafone router at the moment.
I'll give it a go next Monday. Thankfully only working from home one day a week now.
Thanks for your help.
Martin955
Message 37 of 41
Re: VPN issues
I'm able to connect again.
I'll see how long it keeps on for this time.
Martin955
Message 38 of 41
Re: VPN issues
Manged a whole day today, which is the 1st in a long time.
Perhaps the factory reset did the trick.
Fingers crossed for next week
thanks for the assistance.
Anonymous
Not applicable
Message 39 of 41
Re: VPN issues
Fingers crossed 🤞
Martin955
Message 40 of 41
Re: VPN issues
Managed all morning this morning. logged out for an hour for dinner, logged back on but connection only lasted 1/4 hour. can't connect, all I get is unknown error. 😟😠😡
Connect via my vodaphone 4G router & everything connects straight away.
Don't tell me this isn't something that BT is doing regarding the phone line. I wish there was a technical support network at BT that could explain.
