gupster85
Message 1 of 6
VPN on device using BT Home hub 6
Hi all,
So I was happily using my VPN on my tablet and work computer but since upgrading to the Home hub 6, it will not allow me to use a VPN on my device. I can connect to it but when I use it, it doesn’t lid anything. Trying it with my mobile connection, everything is fine.
5 REPLIES 5
gupster85
Message 2 of 6
Hi all,
Tags (2)
Keith_Beddoe
Message 3 of 6
Re: VPN on device using BT Home hub 6
Which home hub were you using before?
gupster85
Message 4 of 6
Home hub 5
Keith_Beddoe
Message 5 of 6
@gupster85 wrote:
Home hub 5
Then just go back to using that, as the HH6 is not really any better, and has a number of disadvantages.
FuzzyLogic72
Message 6 of 6
I use StrongVPN, good upload speed and ping, but hopeless download ( 0.1Mbps ) 😞
I switched off WebPreferences at http://preferences.webaddresshelp.bt.com/selfcare/preferences.cgi as suggested by some searching.
That didn't make a difference ( Ihave left it disabled though ).
However after turning off Extended UPnP security, I now have the same speed with VPN as without.
