Which home hub were you using before?
@gupster85 wrote:
Home hub 5
Then just go back to using that, as the HH6 is not really any better, and has a number of disadvantages.
I use StrongVPN, good upload speed and ping, but hopeless download ( 0.1Mbps ) 😞
I switched off WebPreferences at http://preferences.webaddresshelp.bt.com/selfcare/preferences.cgi as suggested by some searching.
That didn't make a difference ( Ihave left it disabled though ).
However after turning off Extended UPnP security, I now have the same speed with VPN as without.
