Message 1 of 4
Vdsl Faceplate Question
This might sound silly but does the filtered faceplates have a life expecency on them?
I ask because ive had a mk2 since they first came out and i saw a post in another forum where someone said they last for 3 years which mine has done (and then some) so should i replace it even tho i havnt noticed any problems apart from a slight 5Mb sync drop (still getting 73 Mb (hub), 71Mb (TBB speed test))
3 REPLIES 3
Message 2 of 4
Re: Vdsl Faceplate Question
No the do not have a  life expectancy. They are like any electrical item. They will last until they fail.
Message 3 of 4
If it ain't broke don't fix it.
Message 4 of 4
thank you, i suspected so but just wanted to be certain
