Message 1 of 15
Vdsl modem with G.inp?
Hi all,
I would like to use my Tp-link router instead of the smart hub as it gives better coverage, is there a go to decent VDSL modem that supports G.inp. I’m on a ECI cabinet and would like to take advantage of G.inp when it becomes available. I have an Openreach ECI modem but I can’t seem to get firm confirmation that it supports G.inp.
14 REPLIES 14
Message 2 of 15
Re: Vdsl modem with G.inp?
The Huawei HG612 Openreach modem definitely supports G.Inp
Message 3 of 15
The Draytek Vigor 130 VDSL modem also supports G.INP.  Just bought one myself to connect in front of an ASUS DSL-AC68U which has recently had G.INP disabled by BT.
Message 4 of 15
How is the sync on the Draytek?
Message 5 of 15
Anyone got any experience with the TP-Link VR2800, it has a built in vdsl modem and says that it supports G.inp.
I like TP-link and this would be an all in one solution.
Message 6 of 15
I installed the Vigor 130 a couple of days ago and early this morning DLM re-synced my line and switched off interleaving - my latency has dropped way down as I am now back on FastPath and my sync rate increased to 77882 which is as high as I've every had on my line.  My Asus DSL-AC68U was previously getting 72000 with interleaving since BT dropped G.INP support for this model.   It is now just performing wireless router duties on my network.
Recognised Expert
Message 7 of 15
Since when?
I'm still on Fastpath with an 8ms ping.
Message 8 of 15
Yes if you have a good line then you will be on FastPath - my nearby friend is on a shorter line and has the DSL-AC68U as well and they get full 79999 on FastPath.  However if you have a longer line with some errors then DLM will now enable G.INP if you have a compatible modem - if not then it uses interleaving which is what has happened to my line with the DSL-AC68U.  The Vigor 130 seems able to sync higher than the DSL-AC68U on my line at least - this morning it went up to 79997 sync rate.
Some more details here:
http://whatsyourrouter.com/mybb/showthread.php?tid=160&page=11
Message 9 of 15
@Stuartd
I'm using the VR2800. I'm a fair way from the cabinet so I get sync rates of around 30 Mbps. Currently the VR2800 is giving me 32.2 Mbps. Typically I got just over 29 Mbps with the Home Hub 6. I also tried the DSL 68u but that was  slower than the HH6.
Hope that helps.
Recognised Expert
Message 10 of 15
@brookheather Seems that I don't have G.INP enabled after all. That was a very useful link you posted so thanks for that.
