Newbie
Message 1 of 4
Victure PC420 won't connect to Smart Hub 2
Hi
I've been using my pc420 without incident on the previous iteration of my BT home hub (I split the SSID so I has a 2.4 channel). However, they kindly sent me the Smart Hub 2 - and the camera is no more. Cannot connect it.
I can see it's not possible to split the bands on this hub, but I've turned off 5ghz and tried to connect to no avail.
So question is two fold - does anyone have any suggestions about how I might connect this or
Does anyone know of a smart camera that actually works with this hub?
Tia!
3 REPLIES 3
Message 2 of 4
Re: Victure PC420 won't connect to Smart Hub 2
@Toonlara
Why not simply go back to using your original hub that works, as there is no advantage in using the Smart Hub 2, unless you intend to pay extra for the black disc.
Did you remember to disable smart setup on the new hub?
Newbie
Message 3 of 4
Hi, thanks for your reply
I am using a disc as well as I have terrible signal in a bedroom.
What is smart set up?
Message 4 of 4
try this   https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
