Message 1 of 7
Vindar smart plug
Hello I can’t set my smart plugs up via the eFamilyCloud app since moving to BTs smart hub 2.
just won’t connect at all saying to check Wi-fi is 2.4 not 5
tried so many times but no luck is there a way of doing this
love Myrtle
6 REPLIES 6
Message 2 of 7
Re: Vindar smart plug
have you turned of smart setup
Turn Off smart setup
Try turning off the 5ghz network in the hub and then try and connect to the 2.4ghz network  once connected then activate the 5ghz network and device should remain connected to 2.4 ghz
Message 3 of 7
The smart hub 2 doesn’t let you switch off the 5ghz
there are no switches on it as far as I can see.
Myrtle
Message 4 of 7
Myrtle
See https://community.bt.com/t5/BT-Devices/Disabling-5Ghz-on-the-Smart-Hub-2/m-p/2074900#M16090
Message 5 of 7
Myrtle
Yes it does.
Message 6 of 7
Ohh thank you I’ve been looking on the actual hub not via the Bt app.
thank you so much now I can try this!!
Message 7 of 7
That is on the hub, not the app.
