Message 1 of 2
Vodafone Sure Signal and BT Home Hub
Can somebody tell me if there are related problems with the Vodafone Sure Signal and the recent BT Home Hub upgrade because since the recent upgrades, I have had nothing from the mobile signal booster plugged through the hub which has worked fine for a year but has now died.
Vodafone are worse than useless when it comes to support because they are too big to talk to individuals but I am told that this is not a Vodafone issue and that my ISP is to blaim.
I hope that I can be enlightened because if the disconnection is the result of the upgrades then clearly something should have been said.
E-Mail address removed - Mod
Thank you.
Adrian
1 REPLY 1
Message 2 of 2
Re: Vodafone Sure Signal and BT Home Hub
Please remove your e-mail address, as you are not allowed to show it on these forums.
Which home hub version are you talking about?
Which version of the BT Home Hub do I have?
