Message 1 of 7
WAN Lead
When I was sent my BT Halo I received a WAN lead with it for which I could find no use.
In simple terms does anyone know what it is for?
    Regards,  John
6 REPLIES 6
Message 2 of 7
Re: WAN Lead
It's just an Ethernet lead, to connect your hub to a device with an Ethernet port if required.
Message 3 of 7
Re: WAN Lead
  1. Thank you licquorice. What would be an example of a devise that I would connect to my hub using the WAN Lead?                   Regards,  John
Message 4 of 7
Re: WAN Lead
If you have Halo3+ , you have a Hybrid Connect device that provides a mobile internet connection in the event your ‘landline’ broadband stops working, it can be connected to the SH2 router with an Ethernet cable or wirelessly, the Ethernet cable provided may be for that .
Message 5 of 7
Re: WAN Lead
Thanks iniltous, but mine is not a Halo3+
Message 6 of 7
Re: WAN Lead
It's just an Ethernet lead, supplied in case you need one.
Message 7 of 7
Re: WAN Lead
Thanks licquorice
