Malshome123
Message 1 of 6
WIFI Keeps logging devices out
Hi,
I'm a real novice so please forgive my ignorance on these things. Within the last couple of weeks the BT Hom Hub keeps logging devices off. Iphone, Android etc. and its got really annoying. Each time the device is opened it asks which network to connect to. Usually everyone comes and go's and automatically connects.
Any help or advice would be really appreciated.
Cheers
Mal
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: WIFI Keeps logging devices out
Welcome to this user forum.
Try a factory reset of the home hub Factory reset your home hub
gg30340
Message 3 of 6
Try ONE factory reset of the Homehub by pressing a pin into the red recess button on the rear for about 20 seconds. This can often sort out problems.
Malshome123
Message 4 of 6
Thanks both, will try it.
imjolly
Message 5 of 6
If you have hh6 did you separate the 2.4/5ghz networks?  It sounds like your devices a switching between networks or even if you have phone set to select strongest network including 4g then it may in certain parts of your home get a stronger 4g than it does your home network
Malshome123
Message 6 of 6
I followed the advice and reset the hub and up to now no issues. But I also logged onto the Hub and saw that their are quite a few devices logged on. Some are listed under the 2.5 and some are listed under 5. It’s the devices logged on under 2.5 that seem to be disconnecting. 🤔
