Newbie
Message 1 of 3
WIFI SSID bug in firmware of BT Smart Hub
When I split the 5gz and 2.4gz wifi bands on the BT smart hub, I can give whatever name I like for the 2.4Ghz band, but for some strange reason on the 5hz band it only allows 3 alpanumeric characters and the second character has to be a "- "  . My previous vodafone router never had that issue I could give 2  different names for each of the 2 wifi bands, even on an old bt home 5 I have lying around, I dont get that issue when I tried it on that router.
Here is the firmware information for the smart hub
Firmware version:
SG4B1000B540
Firmware updated:
01-Nov-2018
Can you please fix this bug, as Im really starting to regret leaving vodafone as their router worked perfectly.
2 REPLIES 2
Message 2 of 3
Re: WIFI SSID bug in firmware of BT Smart Hub
Message 3 of 3
Presumably you didn't leave vodafone just because BT was offering a HH6 but if this issue it is causing you to regret doing so, why don't you just bin the HH6 and use your HH5 or buy a decent third party router.
