daz2daz2
Message 1 of 5
WPA2 Password
Hi All
I am a new user to BT Infinity and am having problems with my Macbook, as a previous Sky user my Macbook would log on to the router without a problem, now on BT Infinity it asks for a WPA2 password everytime, to the point where I just end up using (cant remember what it is called!) wher you have to log in your BT account details as though you are in a cafe or something.
Everything else I have ipads, iphones etc work no problem, I have not set upo any passwords and just want the thing to connect as it did before with asking for the WPA2 password.
Any help would be greatly appreciated.
4 REPLIES 4
Message 2 of 5
Re: WPA2 Password
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
This a particular problem with Apple devices.
daz2daz2
Message 3 of 5
Re: WPA2 Password
Thank you for the reply, however I cant get my macbook to connect to the Hub as I dont know the WPA2 password, please advise?
Darrel
Message 4 of 5
Re: WPA2 Password
Should be on the label stuck to the bottom of the hub. If not, connect via Ethernet and change it to something you can remember
daz2daz2
Message 5 of 5
Re: WPA2 Password
All sorted now thank you.
