Message 1 of 6
WPA3 routers
Anyone find a WPA3 router that works well with BT fibre connection ? Love the speed don’t love the protocol .
5 REPLIES 5
Message 2 of 6
Re: WPA3 routers
How many times has your WPA2 password been cracked?
Message 3 of 6
Re: WPA3 routers
Not the answer to my question - but thanks . I would like to hear from anyone who has switched to a WPA3 router though !
Message 4 of 6
Re: WPA3 routers
Asus, NG, Unifi and quite a few all support it depending on the model. It’s if the clients support it so most will have WPA2/WPA3 but it’s not fool proof.
As for recommending a router, that’s something you would have to think about depending on your needs as what one person likes or needs the other does not.
Was there something particular that you require WPA3 or you just want to insure a more secure network?
Message 5 of 6
Re: WPA3 routers
Thanks - am sorted. It’s on good advice.
Message 6 of 6
Re: WPA3 routers
What did you end up going for out of interest.
