JohnAP
Message 1 of 15
WPS no longer gets disabled by BT
If I ever had to reset my homehub 3 (type A) I remember that wps became available for a short while until BT disabled it again. However since it upgraded to the latest firmware, wps no longer gets disabled by BT. Does this mean that the security issue with wps has been fixed in the latest firmware?
14 REPLIES 14
Distinguished Guru
Message 2 of 15
Re: WPS no longer gets disabled by BT
Hi JohnAP and welcome
I've noticed this too (and mentioned it on the forums, somewhere). I have manually turned mine off.
I don't know but according to BT it shouldn't be active (yet). This page confirms that it should be off - http://bt.custhelp.com/app/answers/detail/a_id/32232/~/how-do-i-create-a-wireless-connection-to-my-b...
In case there is an error with the latest firmware, I'll flag this post for some clarification;)
-+-No longer a forum member-+-
JohnAP
Message 3 of 15
Thanks for the welcome. It would be good if a mod could clarify this.
zagnome
Message 4 of 15
You should run Reaver and see if it's vulnerable.
Moderator-Retired
Message 5 of 15
Hi All,
That's odd! I have asked the question, I will update you as soon as I get an answer.
Cheers,
Chris.
BT Mod Team
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Community Manager
Community Manager
Message 6 of 15
Hi Guys
Sorry for the delay un updating you.
We recently started to switch on the WPS functionality on our Hub 3’s.  It is being rolled out over the next few months so some hubs have had this enabled already but it will take a while to have this rolled out across all hub 3.0s.
Rest assured that we would not be doing this if there were any security concerns in switching on WPS.
Cheers
Distinguished Guru
Message 7 of 15
Thanks for that Sean:)
So the page I linked above will be changed to include this (unknown to a customer till now) info?
JohnAP
Message 8 of 15
SeanD, many thanks for the confirmation.
jamiedanjoux
Message 9 of 15
I am with PLUSNET and I have my Hub 3 connect to my fibre service. Will this still be unlocked to get WPS again? My hub is a type B
jamiedanjoux
Message 10 of 15
Is there a way I can force my Hub 3 to enable the WPS function like doing a firmware update etc....?
