Message 1 of 4
Warm reset every 14 days!!!
I have a Smarthub and it is doing a warm reset every 14 days. Is this normal?
Also it is happening at 4pm, the middle of the afternoon. Is there anyway of getting shifted to over night?
Wren
3 REPLIES 3
Message 2 of 4
Re: Warm reset every 14 days!!!
You can try by getting up in middle of night and doing a reset of your own.
Message 3 of 4
So it is normal and will continue to happen?
Message 4 of 4
there are many posts about the hubs resetting at 14 days some even 7 days but as long as connection is same before and after reset then it is more annoying than anything else.
I used to reset late at night and then 14 days was not a problem for a while.  there is no solution apart from a different make of router but mine 14 day reset just stopped and been fine ever since
