bikeit
Message 1 of 13
Weak Wi - Fi
I am currently using BT HH3 but the wi fi signal is so weak upsatirs it takes ages to load pages and it wont even let you print wireless, so am i better to get a new HH5 or a different branded modem / router or get a wi fi booster kit?
12 REPLIES 12
gutted
Message 2 of 13
Re: Weak Wi - Fi
i have just had a hh5  installed i find the wifi very weak compared to the ee router i used before
bikeit
Message 3 of 13
Re: Weak Wi - Fi
Oh thats bad
Message 4 of 13
Re: Weak Wi - Fi
If you are going to spend money you would be better to buy a third party router. If you stick to the well known brands such as Netgear, TP-Link etc you won't go far wrong and will be better than a cheap mass market Homehub.
bikeit
Message 5 of 13
Re: Weak Wi - Fi
So it a VDSL 2 modem router i need to look for?
Bigmac77
Message 6 of 13
Re: Weak Wi - Fi
I've been very impressed with my HH5 wifi, it's even better than my old Billion 7800n and I thouhgt that was good.
bikeit
Message 7 of 13
Re: Weak Wi - Fi
If i was to get a lend of a HH5 is it easy to set up, and would the person who lent it to me have to do anything when i give it back to them or is it simlpe plug and go?
Message 8 of 13
Re: Weak Wi - Fi
If you can borrow one it is just plug and go. You will need to use the wireless passkey that is on the label if you want to connect a wireless device.
bikeit
Message 9 of 13
Re: Weak Wi - Fi
Cheers guys, looking at other options like TP link Billion and netgear, but if im being honest i would like to do this without spending too much money.
Message 10 of 13
Re: Weak Wi - Fi
If you are on Infinity with an white Openreach modem and the Homehub 3 you could just replace the HH3 with a router for about £30. Just make sure that the replacement has a WAN socket. You do not need to replace it with a VDSL modem/router unless you want a one box solution.
