Message 1 of 3
Weak signal from BT Hub.
OK, first time here so please be patient.
I have a house with no landline.,The house is only used as a weekend retreat.
  There is a BT hotspot nearby  and I can get a signal on my iPad if I stand at the bottom of the garden, however If I move nearer the house, I lose the signal, presumably I am at the limit of the signal.
Is it possible to get some sort of booster or relay gadget that I can fit up to boost the signal a bit so that I can use the iPad in the house.?
 I would appreciate any advice,particularly in plain speak, as I am not tech savvy.    Thanks in advance.
2 REPLIES 2
Message 2 of 3
Re: Weak signal from BT Hub.
Simple answer, no.
Message 3 of 3
That's fine, that saves me messing around trying to find a solution which does not exist.
Thanks for your quick and helpful reply. I guess I will just have to stand at the gate and use the signal there.
Have a good one         Bill.
