mjianu
Message 1 of 14
Web server
I have a Smart Hub 2. And I setup a Webserver on a CentOS , with Apache 2, is working on local ip address, but when I try to go globally (even i attached it to a DNS name)...but instead to load the website from server is just loading smart hub 2 manager from router...I created on router a new port forwarding rule...named it webserver, put ip of the local server, external ports start 8080 end 8081, internal ports start 80, end 81, protocol TCP...why is not working?
13 REPLIES 13
licquorice
Message 2 of 14
Re: Web server
I suspect you are trying to access it locally via your public IP address. You need to access your public IP address from outside of your home network, eg using a 4G mobile signal.
mjianu
Message 3 of 14
Re: Web server
Is not loading at all , if I am on my 4g
licquorice
Message 4 of 14
Re: Web server
Have you tried forwarding port 80 external to 80 internal rather than 8080.
licquorice
Message 5 of 14
Re: Web server
Silly question time.
Are you sure you are saving the rule. You need to click on the + sign and then Save.
mjianu
Message 6 of 14
Re: Web server
Done it...still no
licquorice
Message 7 of 14
Re: Web server
Are you sure the webserver is listening on port 80?
licquorice
Message 8 of 14
Re: Web server
Try turning off UPnP
mjianu
Message 9 of 14
Re: Web server
mjianu
Message 10 of 14
Re: Web server
Is 44
