StueyG
Message 1 of 23
Website access via HomeHub
I am having problems accessing some websites via my Smart Hub.  The sites seem to mainly be https ones (eg mydonate.bt.com, Santander) but I can access some secure sites OK (eg Amazon, Tesco).
I can access the problem websites fine via a mobile hotspot and have tried other laptops through the Hub and had exactly the same issues.
I have tried a factory reset on the hub (using the button on the back of the hub) but no success.
Anyone had similar issues....and found a solution?
22 REPLIES 22
Message 2 of 23
Re: Website access via HomeHub
It could be DNS issues. If you have a laptop or desktop computer, then try changing the DNS server settings from automatic, to Google Public DNS  8.8.8.8 and 8.8.4.4 and see if it helps.
StueyG
Message 3 of 23
Hi Keith
Many thanks for the prompt suggestion.
I have tried changing the DNS addresses but that has not made any difference I'm afraid.
Best Regards
Message 4 of 23
Did you flush the old DNS cache?
StueyG
Message 5 of 23
Yes - no success.
If it helps, the error message is
"This site can’t be reached
mydonate.bt.com took too long to respond."
Message 6 of 23
Have you tried changing IPv6 DNS to 2001:4860:4860::8888 and 2001:4860:4860::8844 as well?
Message 7 of 23
It sounds like a routing issue. If you have restarted the home hub a few times, your public IP address should have changed, and in theory the routing.
Try this address https://www.btplc.com/mydonate/index.aspx which the DNS entry points to.
StueyG
Message 8 of 23
I hadn't....have just made the change....and no success.
StueyG
Message 9 of 23
Can't access the link - same error message about Too Long to Respond
Message 10 of 23
Can you do a tracert to the host?
 Also try the direct IP address 212.140.56.90
