Newbie
Message 1 of 3
What the Dickens is this entry in my port forwarding?
Good Lord, people, what is this entry in my port forwarding page that I cannot delete? Do I have the beady eye of Crouching Tiger on me?
Reminders web developers they're not software engineers since the 1990s.
2 REPLIES 2
Message 2 of 3
Re: What the Dickens is this entry in my port forwarding?
Welcome to this user forum.
Its been automatically created by an application running on the device with that IP address.
Its using UPnP, so if you do not know what the application is, then disable UPnP on the home  hub.
You may have to follow this sequence to get rid of it.
Factory reset the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Newbie
Message 3 of 3
Bloody childredn, thanks, I shall track down the offending device and review.
Many thanks.
