mattberryman
Message 1 of 6
Where to buy an extra Hub Phone for HomeHub 2.0
Hi,
I have a Home Hub 2.0, running software 4.7.5.1.83.3.31.1.1 (Type B), which was supplied with a Hub Phone 2.1B. Inside the phone's battery compartment is a sticker that says that it's model 044664.
The only Hub Phones that I can see to buy are model 044662. For example, see this phone at the BT Shop
I have read that only Type B phones work with a Type B HomeHub, so can anyone confirm whether this phone will work with my HH? If not, can you suggest where I could buy one that will?
Thanks in advance,
Matt
5 REPLIES 5
Message 2 of 6
Re: Where to buy an extra Hub Phone for HomeHub 2.0
I have never seen that mentioned before. I cannot see any reason why it should not work, the DECT base station within the home hubs are the same, as far as I am aware.
There are quite a mixture of homehub 2s out there.
There are some forum threads relating to the hub phones
http://community.bt.com/t5/forums/searchpage/tab/message?q=hub+phone
Distinguished Guru
Message 3 of 6
You could purchase a type b hub phone from an Internet auction site, but I strongly recommend that if you do, it's still sealed as it would be if you had bought it direct from BT - there are many knackered phones out there
Purely as an example, I have no interest, here is one - type b hub phone
-+-No longer a forum member-+-
mattberryman
Message 4 of 6
Thanks for that information.
I'll try to get a sealed one from eBay.
Thanks again, Matt
smev
Message 5 of 6
I have a type B hub (a replacement for a type A), and am using it with a type A hub phone.
Distinguished Guru
Message 6 of 6
Thanks again, Matt
No probs, let us know how you get on.
