meridius
Message 1 of 3
Which BT Hub routers can handle more than 1 XB1 with open NAT ?
Hi all
I have a BT Home Hub 4 and now have two Xbox One's but I can not get two of them to have open NAT at the same time . I have used static ips  on both and put both xbox ones on  different ports from each other and assigned the ports to each.
I have different IP addresses  Both my XB1  I used  port forwarding settings for both IP addresses.
I did read this
Note not all routers can handle more than 1 XB1 with open NAT,
so does the Hub 4 support this and if not do any BT hubs support this.
thanks
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2759601729.png[/IMG][/URL]
2 REPLIES 2
meridius
Message 2 of 3
Re: Which BT Hub routers can handle more than 1 XB1 with open NAT ?
anyone ? trying to get this work
meridius
Message 3 of 3
so no help on this at all, know one knows if the new bt hubs support this at all ?
