Pdc95
Message 1 of 2
Whole Home WIFI
How many Mobile Phones can be used to monitor / change a Whole Home WIFI setup.
Pete
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Whole Home WIFI
Hi @Pdc95 Sorry we could not answer your question about the number of mobiles you can use to monitor or change the set up.
You would be best to speak with the product helpdesk on 08081006116 Mon - Fri 9.00am to 5.30pm and Sat 9.00am to 2.00pm or drop them an email: btconnectedhome@bt.com
Cheers
John
