Hi,
For some years I have had 6x BT whole home white discs. Configured for daisy chain operation via the web setup interface and with just the master disc 1 ethernet connected directly to my BT home hub 5
A second Lan output from the BT home hub 5 feeds an unmanaged Netgear 8 CH GS108 Gigabit switch and from that is fed a 4 CH GS108 up in the loft.
I plan to connect x1 or maybe more of the furthest discs with an ethernet cable.
Q1/ Can I simply ethernet connect the furthest away disc to the 4CH GS108 switch?
Q2/ Or should all the discs be ethernet connected back to the same switch as the master dsic?
Q3/ Or should they ideally all go back in fact to BT home hub5 ?
I guess the main question is - can you mix discs between different unmanaged gigabit switches without problem?
Any thoughts appreciated
